OK, I have been battling this for half a year now. I have a Mercruiser 140 Hp (1978) freshly rebuilt by machine shop, bolted to a 1967 Merc I ez-shift (1.84:1 ratio) All of this inside an aluminum starcraft hull (starchief, 1967)
No matter what I have done my max RPM is 3600 RPM. I have installed a water seperator/ fuel filter; removed the primer bulb that was on there before; rebuilt the carb; tested the fuel pump; inspected the hull; changed the prop from 19p to a 17p (with absolutely no change in RPM) checked and rechecked the throttle cable and throttle plate are both fully open. The timing has been done twice ( including the advance timing).
So I am now dumbfounded. no idea why the rpms stay so low especially when I repitched the prop and still can only get 3600 rpm when the manual is telling me I should be in the 4100-4600 range.
Thanks in advance for your time in trying to help resolve this issue.
