probably stupid on my part, but got new wiring for trailer (Peterson kit). It had no instructions and for the most part none needed. However at the lights there are no wires coming out of the light only holes to push the wires thru. they are well marked as to color wire and where but how do you get these to push thru to the spring like wire binders inside? the wire just bends when I try to insert it.
Also (might should start new thread for this) I'm going to attach lights to a board and strap across rear of my small fish boat. to take off at launch. If I run seperate ground for each light will there be a problem?
