Hey guys, got an interesting one here. I have a 1987 Bayliner trophy 21ft with 3.0 I/O hard top (no power steering). I have noticed since i bought it that the steering is tight and makes this groan when turned in either direction, went to investigate this year.
I disconnected the pin from the steering arm, the outdrive moved freely back and forth with no problem or groan.
While disconnected I turned the wheel, it also moved freely no groans, not tight.
I then hooked it back up @ the steering arm (outdrive), and disconnected cable and mount from the steering wheel shaft. I turned the outdrive back and forth, no groans, not tight.
While disconnected, turned the steering wheel, moved freely, no groans, not tight.
Greased everything up, put it back together......groaning and still tight.
Any ideas would be appreciated, I am very mechanically inclined so shoot anything at me. I will try to attach some pictures of my steering ends.
Thanks in advanced.
Bruce
Thanks in advanced.
Bruce
