Re: 1988 mercury gamefisher 15hp
Just had this same problem with an '88 15hp merc. Ended up being the switch box. Found one on ebay for 108.00 plus shipping. Could also be the switch, or stator. You can check those with a multimeter, I did this by testing leads while someone else turned the key. Stator should put out about 250-400 volts ac. and the switch puts out a very light signal. One will be the brown/white, brown/yellow wires. The other will be the black/white, black/yellow wires that connect on the side of the switchbox. If they both are sending properly, and still no juice to the coils, then its the switchbox. Hope this helps...
Derrick.
