Hi all,
I have purchased a used 1990 20 hp Johnson two-stroke and and trying to get it in shape to use. Everything seems fine and it starts easy and it runs great at full throttle and will even idle great most of the time. However, occasionally it coughs pretty hard and during the cough, the motor slows down significantly and loses power, then it runs fine again for a little longer before coughing again. I noticed when running it in the dark that a orange blast is visible when it coughs right around the bottom right side of the bypass cover gasket. It is clear that the gasket has blown in that spot. I intend to replace the gasket, but I am concerned about why it is blown in the first place. Will this happen again? Is there something else inside the engine going on (like a bad valve or blow-by past the piston) that I should be concerned about? Will replacing the gasket solve all my problems? Thanks for your help!!!!!
Ryan
Ryan
