Be sure to install the Thrust Bushing and the Thrust Washer, in addition to the Propeller Nut and Cotter Pin.
do I have to replace them or can I use the ones that would be there as of now?
Is that the rubber washer in the prop that breaks away if I hit something?
ezeke said:I don't think that anything has changed. The parts are #46 and #54 in the diagram.
Hey guys I am getting a new prop for my Johnson 9.9 and as of now the nut that is on the shaft is not but up against the inside of the prop. I am woundering if it should be and if not how much spaces is needed between the prop and the shaft nut?
