Hi,
I have a "funny" iddle problem on my F115 (2003), I am trying to explain and find some help.
When I start engine, it starts immediatly and after a few seconds it idlles at 700 rpm, OK very good, like new. After a few minutes, engine begins to cough and stops.
When I start it again, it does not start immediatly but only after 2s ou 3s and a lot of motor rounds and then it iddles at 900-1000 rpm even with gear engaged which is to high for me. (at 900rpm boat speed is 3.2 knt)
This problem remains independant if motor is cold or warm.
So, randomly, if engine starts immediatly and I run at 700rpm, it stops after a few minutes and if it starts after a lot of rounds, it runs at 900 rpm and does not stops, I don't know if I am clear ?
I cleaned VST an ISC, I adjust TPS and fuel admission is perfect, change fuel filters, thermostat is new.
F115 runs perfect at higher speeds and WOT (5600rpm)
If someone has got an idea about this problem, I would be very pleased.
Many thanks
Lo?c
France
Many thanks
Lo?c
France
