I have a 1997 Mercury 200 EFI that I recently purchased. Ever since I've had it, when you take off and give it wide open throttle (WOT), it would pause at 2,000 RPM's for a second or two and then take off. Now the problem is getting worse and sometimes it pauses for 10-15 seconds before taking off and sometimes it will just hang at 2,000 RPM's indefinitely even though throttle is wide open.
As the problem is occurring, I can pull it back to neutral and rev the motor with no problem throughout the RPM range and its very snappy. But then I can immediately put it back in gear and it continues to hold at 2,000. Once it does take off, it runs great and I can slow down or speed up as long as I don't come all the way back to idle.
Any thoughts??
Any thoughts??
