is there a way i can make the wr500g faster?
lynnboy021 Chief Petty Officer Joined Jan 27, 2008 Messages 553 Mar 28, 2010 #1 is there a way i can make the wr500g faster?
T The Penguin Petty Officer 2nd Class Joined Mar 16, 2010 Messages 138 Mar 29, 2010 #2 Re: 1988 wr500g it's a 500cc engine, with a very small jet pump - there's not much you can do to it to get more out of it. even if you did an engine swap for a 650, the small pump is going to hinder performance.
lynnboy021 Chief Petty Officer Joined Jan 27, 2008 Messages 553 Mar 29, 2010 #3 Re: 1988 wr500g what does the pump do and can i get a bigger one?
T The Penguin Petty Officer 2nd Class Joined Mar 16, 2010 Messages 138 Mar 29, 2010 #4 Re: 1988 wr500g the pump is what "pushes" the water out the back of the ski to propel it. no, you can't easily put a larger pump in. It could probably be done - but it would cost more than the ski is worth.
