trevtt600
- May 17, 2009
- 80
Hey guys. Here is my dilemma. I am replacing my 3.0 mercruiser which currently has the valve cover mounted shifting. I have been having problems with the shifting out of foward and reverse even after a new shift cable and following the adjustment procedures.
The new to me motor I just bought has the side mounted shifting on the manifold. I was going to switch out my manifold off my old motor to the new motor, but my manifold of the old motor does not have the mounting points for side mounted shifting. Im thinking about just switching the manifold and the valve cover off my old motor to the new motor and using the old shifter hardware.
My questions is, with my old motor having shifting problems, im a little nervous using the same shifting hardware. Im thinking that the shift interrupter switch is bad on my old motor. I could just switch the two interrupter switchs and hope the solves my shifting issues. What do you think i should do?
I was also thinking of just buying a new manifold with the side mounting points and swapping the hardware over. Ideas?
