ChrisfromVT
- Sep 8, 2009
- 82
1987 115hp inline 6...
Just changed water pump and the motor fires up and runs nicely but I noticed that water is shooting (at a pretty good rate) from the hole for spark plug # 1 and 6. All the plugs had a bit of milky residue on them like water had gotten on them. The #6 plug looks dry but I haven't checked for spark on that cylinder as I wan't to determine the cause of the water leak first.
Could it just be the water jacket seal?
I've only run this motor on the muffs since I've had it and I was ready for a test run on the lake before noticing this leak. Again, no issues with startup, idle or throttle, just a mess of water coming out around the plugs.
