Re: 1977 175hp start truble
Once the engines fires the fuel bulb is supposed to go soft because it becomes a flow-thru device.
If you keep pumping the bulb does the engine keep running,
but if you don't pump it ...does the engine quit?
If you have to keep pumping it the fuel pump on the engine has failed.
=IF= the bulb goes FLAT then thats a different problem but you didn't say so.
1977 is a few yrs and you can expect anything to fail at this point but if you stay on it and do the mainatinance it should be a good runner.
This is new to you, the best money you can spend at this point before getting too far along is the factory service manual, its the best $50 you will ever spend on a boat, its gonna save you a fortune.
Get the model number of your outboard and look it up, order the book.
Don't buy a seloc or other 3rd party book, get the genuine OEM.
www.outboardbooks.com
I would go through the whole engine and make sure all the critical systems are in good order. The manual will help with that immensely.
The things to watch are;
water pump.
Carbs
gear oil.
Compression test ea cyl and write the numbers down.
Decarb engine.
If you do the work you'll have peace of mind.
Post your location too.
If you don't when any of these were done previously they should be done, its all simple DIY.
