Shrill Noise - Volvo Penta 5.0 GXI
sccruzean
I changed my raw water pump and belts on my volvo penta 5.0 gxi. When I started it up, it ran great for about 10 minutes, then all of the sudden a shrill noise started coming from the thermostat area and the motor began to bog down. I quickly turned it off.
Has anyone had this happen before? Is this an alarm or something else? How can I fix this?
Thanks for our help.
Black as
Re: Shrill Noise - Volvo Penta 5.0 GXI
May be your belts are slipping ?
CaptainHook
Is it a serpentine or V belt? Tensioned correctly? Any water leaking possibly getting on the belt????
smokeonthewater
you WERE supplying water to the engine while you ran it for 10 minutes weren't you
bruceb58
Something seized up. Take all your belts off and spin everything and see how they feel. Is you water pump mounted on the front of the crankshaft or seperate and driven by a belt?
What is your full model number?
