bassfearmee
- Oct 11, 2007
- 48
I have an 89 Evinrude 50hp 2 stroke, VRO removed. I purchased this motor last summer, and it ran fine for two months, maybe a little rough but it still ran fine. I decided to check the timing in August and found that it was -8 degrees BTDC (8 degrees AFTER TDC,). The timing should be 19 degrees BTDC. So I adjusted the adjusting screw on the linkage, but I can't get it past 2 degrees BTDC. I've adjusted the screw as far as it will go. I went as far as removing the little black plastic adjustable arm that links the timing base and the linkage, and shortened it to get the timing base to come out more, still no result. Should I remove the flywheel and inspect the base? I'm certain I'm using #1 cylinder with my timing light. Timing light is used. I've also noticed a black gue that seems to accumulate under the two relays that control the trim pump. Everytime I clean it, it gets back in there and occassionally the trim pump won't work due to the gue preventing contact between the relay connectors and the relay base. I wonder if that gue is coming from the top of the engine?
Any help would be greatly appreciated.
Thanks,
Bob
Thanks,
Bob
