I have a 1994 Evinrude 112spl outboard. I took the lower unit off a few weeks ago to change the impeller. I removed the carbs to see if they looked gummed up. They looked fine so I just sprayed them out with carb cleaner and put them back on. It started a little hard the first time this year and it seemed like it wanted to flood and then die. Once I pulled up the high idle lever enough it ran fine. When I put the lever back down it seemed to idle higher than I remember. With the muffs on in neutral and fairly warm it idled at 1500rpms. Is that too high? I am hoping that my memory has just failed me.
