gunlocators
- Jul 27, 2009
- 65
I have a Johnson 150 VRO 1988 Model. The Oil injection was disabled by previous owner. Boat has been sitting for 2 years. I finally got around to mess with it fist thing I did was a compression test. All 6 cylinders are 75psi I think my gauge is ok but do not have another to test with. All cylinders are within 1/2psi from each other. I had a buddy say if the rings are dry it may need ran then recheck the compression. I started the motor for just a few seconds and it sounded great except I had to kill it the fuel pump was leaking so a new fuel pump is on the way but we did not run long egnough to test his theory. With the 75 psi should I be concerned since all 6 a all most dead nuts the same compression. Should I run it and recheck is it possible the compression can increase?
