Jack_toda_Max
- Mar 21, 2010
- 22
Hey guys,
I have a 1962 Evinrude Starflite IV 75HP with Selectric Shift.
The OMC repair manual says to use OMC "Type C" gearcase lube in the lower unit. But I've read that it has been discontinued and now the correct lube is "Premium Blend Gear Case Lube"
I found the Type C lubricant in the iboats.com online store.
http://www.iboats.com/Type-C-Gear-Oil/dm/*******.986715963--**********.708999429--view_id.45019
Can someone verify that this is the right stuff? How much will I need?
Thanks,
Jack.
Thanks,
Jack.
