Could someone help me identify the shift switch on my 1988 125 force engine. I believe it is located on the engine via a bracket near the throttle linkage. This switch is wired directly from the solenoid thru this switch to a yellow wire (start) at the connection bracket/bar. If this is the shift switch could this switch cause my ignition problem? How do I check the switch?
