Hello all, trying to help a buddy on his 97 225 (carb) saltwater series. In neutral the engine starts up fine but when you put it in gear it will run as long as you dont advance the throttle more than 2000 rpm it start coughing and then then quits. But if you leave it in Neutral you are able to advance the throttle up to 5000 rpm no problem. Were are scatching our heads now!!!!
Any thought would be great Thanks.
