Re: shoot thru hull
Sorry for the delay, I just took these.
This is a shot of the engine, and the shoot thru is in the bottom left corner of the pic, below the water separator/filter.
And a closer shot, hope this helps some. I actually test fitted it in a few different spots, this spot gave me the most accuracy. This one is for a backup depth finder(humminbird 610) I have a Raymarine A65 with a transom mount triducer, and 99% of the time the 2 readings are identical.
You can see where I got some of the epoxy splooge on a hose :redface:
