Yep, 2000# (unless it is the Grand Cherokee then it is 5000# (per the manufacturer).
Tom P. Regardless if you know the vehicle limitations (braking, acceleration, ect.) you are still exceeding the SAFE towing limit. ALL air bags, add a leafs, full suspension kits do is increase the LEVEL towing capacity of the vehicle, they do not increase the total capacity. The vehicle is still overloaded (also keep in mind that 3500# boat when fueled, and geared up and you have a passenger is probably closer to 4000#--double the recommended towing capacity of the truck).
That being said, when an air hose brakes you lose the bags and are right back to a stock suspension. I've had air shocks on 2 different trucks (that I kept for about 4 years and never had an air line failure. I've air bags on the front of my plow truck for 2 years and no failure so they are pretty reliable.
