fishKILLER1987
- Mar 22, 2010
- 86
I just inherited a Robalo offshore fishing vessel. However, I believe it has seen better days. It was damaged during a hurricane and hasnt been touched since. The extent of the damage is a hole on the port side of the vessel where I believe a tree had fallen on it during the hurricane. The hole is about 10 inches deep and around 1 1/2 ft. wide. The tree completeley smashed a small section of the port side. Looking into the hole I can see exposed fiberglass and what looks like some kind of wood or dense foam used as the core of the hull.
My goal is to fix the damaged side and completeley strip and repaint the entire vessel. I have worked with fiberglass before but i have never repaired something of this nature. My only questions are:
Can an impact such as this one be repaired?
If so, can anyone shed some light as to where I may be able to find a good book or set of guidelines to go by?
I've been a Do-It-Yourselfer for quite some time and a little work has never stopped me from taking on major projects. I also have a wide variety of tools and decent facilities for which to work in.
Thank you for reading my post and any help is greatly appreciated.
**I can also post pics of the damage if need be.
