Rule 1100 GPH Livewell pump as wash down ?
cribber
Re: Rule 1100 GPH Livewell pump as wash down ?
For a raw water washdown you could likely plumb it in with tubing and pvc pipe. It all depends on what the lift capability of the pump as to what type of pressure you'll get. Is it transom mounted?
Ayuh,... You can try it, but I believe you'll be severely disappointed...
It's just the wrong kinda pump...
Joseignacio
Yes it is transom mounted. I was just afraid if it could run while the pistol grip hose was shut.
joe009
my boat came with a live well/wash down pump.it did not put out enough pressure on the wash down.i added a separate wash down pump.
Joseignacio
Not enough space. It will have to be above deck. I'm not looking for much pressure as much as running water to use while fishing. Do you think these type of pumps can run with the hose shut and not burn?
Pez Vela
Can I use a Rule 1100 GPH livewell pump as my wash down pump ?
Yes you can if you want to just dribble water on your deck.. If you had asked whether it will work or not, I would have said no. You will need a pressure pump for wash down purposes. I love my Rule 1100 for my bait system, but that's it.
