I haven't started my 115 since rebuilding it (just getting over the flu) but I have some concerns and a couple of questions. 1st I am not getting any power to my keyswitch. This morning I went out and jumped the starter from the battery to see if I had a good engine ground and it cranked OK. This brings me to my second concern/question.
While I had the plugs out and was messing with turning it over with the starter I decided to do a quick compression test. I was not thrilled with the results. 80 psi on 2 cyls and 90 on the other 2. In the past this engine always tested between 115 and 120 psi. My question is should I get that much of an increase in compression once the engine has been ran a little and the rings have seated? I'm also thinking of borrowing another compression gauge just in case mine is out of calibration. It's the same guage I have always used but it has been sitting in the garage for a year without use so there is no guarantee the guage is in the same shape it was in when last used.
