I purchased an '88 115 inline on a used boat from a relative. Before letting it set in the yard for years he had the carbs rebuilt because it wouldn't come out of the hole unless you babied it . .Well the relative said the carb rebuilds fixed it but his wife said his memory is poor. It didn't help at all. When it gets over a breakover point it runs like a motor really should. It can get my bass boat up to about 45 mph according to the spedometer. I removed the tank and cleaned it and replaced the fuel lines and filter and that didn't help. I took the boat to a highly praised mercury dealer here in town who has helped me in the past and he didn't remember he had built the carbs about four years earlier and said I needed to have them rebuilt since it had set for so long with gas. As told to me by an employee, after he had the carbs off and apart he realized that they were clean and his records showed he had done the rebuild i mentioned above. He called me and said sorry but its not the carbs, its the reed valve packs. He said on the inline six, the reed valves are set up in a unit similar to main bearings around the crankshaft (there are three of them according to my mechanic) and the wear between the reed valve packs and the crankshaft have worn and postmixed gas/air is leaking into the lower cylinders past the crank and I have to replace the reed valve units at $1200 in parts plus labor. No adjusting to the carbs helps either and I still have the problem. Can this diagnosis be correct and are there any workarounds? Oversized idle jets? Either injection kits? Any suggestions?
