Re: Trailer connection 4 pin to 5 pin on truck
Well let's start. take your test light and check the power from the truck. one end on the ground pin the other on the power for the marking lights. if that's good go to the steel bumper for a ground. if no light go from bumper to plug pin ground, if it lights you crossed ground and marker pin. if not crossed go back to truck marker power pin. if you have light go to trailer and truck marker pin. if the trailer is hooked up there will be enough ground threw the coupler to light the test light. next is truck marker pin to trailer marker pin. if no light on tester you have broken circuit on trailer. check the first marker light on the trailer with the test light still hooked up to supply power (truck marker pin)and the trailer marker pin. bulb OK? check for a ground at the light. if there is one there the bulb should work. you can use a piece of wire to ground out the ground side of the bulb if there is no ground. if no light, remove the bulb and ground the power side of the bulb plug, the test light should light, if not the power wire/trailer plug is bad to the first marker light or you blew the fuse in the truck. take the tester back to the truck if it lights the truck's fuse is good. if the marker bulb lights, when you ground it out you have a bad ground on the trailer (sinse the brake lights work make sure your good to this point, the ground could be good). if there is a ground at the first marker fix it, if the ground is farther down the line, plug the trailer in and take your tester and go between the first marker light bulb ground side and the trailer to get a good ground. both the bulb and the tester should light again. now look at all the marker lights and find the one that has the ground wire (it's usually a wire from the last marker to the trailer). fix/repair. that will usually fix all the lights, if not you know how to test the markers now one by one. take your time and be careful not to blow the fuse when you go inside of the sockets with the tester/wire. good luck.
