Hi I have a 1997 40 HP Force. For some reason my tilt and trim pump is running in the up position without pushing the up button. I checked the wires on the switch and everything is okay. I even unplugged the switch and have the same problem. The trim motor keeps running. So I replaced both relays with no success in solving the problem. I was able to disconnect the wires supplying power to keep it from Burning up the tilt and trim motor. I reversed the wires and was able to get the motor to go down. What would cause the motor to have power to it all the time? Any help would be greatly appreciated. Thanks
