Re: Roller Trailer to Bunk Trailer Conversion
We mounted the 2x4 sections end wise, and simply drilled two holes in each board to correspond to the spacing of the roller arms. The boards were simply held in place just like the rollers were. I came up with this set up after my buddy suggested that he could simply make wooden rollers at work for nothing. Figuring that wood rollers would only split and result in a damaged hull, I made the 2x4 mini bunks. The individual bunks sort of self limited their own travel, the shafts they were mounted on would only move as far as they would have with the roller on them. The ends of the wood were also rounded off a bit on a belt sander. This trailer used steel roller arms, I believe the brand was EZ Loader.
I never even thought about top mounting the bunks as in the pics above, it just seemed natural to just drill two 3/4" holes in each bunk and attach them using the same hardware that held on the rollers. This way there's no screws to come loose, or nuts or bolts to rust, just cotter pins and washers.
The wood was free, they were cutoff pieces given to me by a neighbor/contractor, and carpet was regular indoor/outdoor carpet, I bought a huge remnant a number of years ago and have been cutting strips off it for years to cover trailer bunks. I think I paid $10 for the 10x15' or so piece at a local carpet outlet. The carpet is attached with spray cement, gotten from work, and stapled along the bottom edge with stainless staples, about $8 a pack, which will do about 5 trailers.
Rollers for that trailer were $10 each, plus hardware kits, $4, making the rollers $225, plus shipping. The nylon glide strips were take offs given to my buddy for nothing.
