antique fisherman 1
- Feb 25, 2010
- 31
If you disconnect the fuel line at the carburetor on a '66 50hp Chrysler motor, how much should come out with the starter spinning the motor?
Thanks FrankIt should pulse rather strongly. Squirt a couple of inches, not dribble. Enough that you would want the hose end in a container. If I remember correctly, the numbers quoted are 2psi at cranking up to 6 psi at running.
This assumes that the primer bulb was used to fill the fuel line and carb before removing the hose and cranking the engine. The fuel pump will NOT deliver enough fuel to self prime by cranking the engine.
