Re: Mercury Force History
I am good, but not great! You had to ask the one question to which I have no answer: I never worked on a jet drive Force.
Before we start though, reconsider. You do not have a lot of options. You can swap in a Force 120 or 125 block, or even a Chrysler 140--maybe.
Now, since a jet drive is only 75% as efficient as prop drive, any extra horsepower you swap in will be reduced by 25%. So even if you go whole hog,you can only expect maybe 4-5 MPH more. Now, if your engine is trashed, then it is worth getting the larger block. But otherwise, you are better off leaving it alone. AND: if you do swap in a bigger block, you still need to change the jet pump impeller to absorb the extra ponies.
NOW: IF and that's a big IF--If Merc did not change the splines on the jet drive crank, then, any Chrysler or early 90s Force 120, 125, 140 block will bolt up. And possibly the 5 cylinder 150--but then for sure you will need to "Massage" fiberglass
However they may have used a differently balanced crankshaft (like on the L-Drive, according to an old Chrysler mechanic)
All in all, If you want more performance it is really time to look for another boat.
