Hello new to the forum! i am going to look at a boat that has a 1988 mariner 115 on it. the guy said it was just checked out last year by a shop . it starts and runs good on the muffs. it has had the auto blend system removed and is pre mixed in the tank. i was looking to find out how good these motors are and if there are any known problems to look for? also can i just fill the gas tank up with gas then put in the correct amount of oil and alittle more gas to mix it or should i pre mix in gas cans? it has a 20 gallon tank and is on a 1983 lund tyee. will this motor troll slow enough to pull crank baits? just looking for a little info before i pull the trigger on it . thanks
