When I try to tilt up, you can hear the tilt motor, but it wont push it up. If you lift it up manually, the piston will rise all the way and hold, but then even if you press up on the tilt, it goes down. Same with the trim. Any ideas. This is a 1988 Johnson 90hp VRO. Also what kind of fluid do I put in the tilt motor. Thanks
