Well, had to explain in words, but I will try.
I have a 2002 Yamaha 200 HP OSX. I live on the gulf coast of Texas in a waterfront home. I say this because this engine is run often. This winter I began to have problems starting. Took the battery out and check it and it was in good condition. Came back, reinstalled it, and got the power I needed and the engine cracked and started.
Well, I have been traveling a lot this winter and went to "fix" the boat. So, replaced worn parts (blidge pump cartridge, fixing wires. etc.) and tried to start it. It acted like it was seized. The engine has set for 4 months over water (not in water). So, I removed the spark plugs and and tried to turn the engine by hand and couldnt. So, I went and bought some "Liquid Wrench" and sprayed inside the cylinders. Then, waited about 15 minutes and put a wrench on the flywheel bolt and slowly turned the engine. Was difficult. All pistons coming up and down.
Reconnected the starter and turned the key with the plugs out and the engine turned very slowly. Then, put the plugs back in and then turned the starter and it wount budge it. Which, I though was strange. I should have pushed through the compression stroke.
Anyway, I am wondering if the lower unit can get a little siezed up or stiff?
Could I have a weak starter?
Thanks in advance
Thanks in advance
