What did the seller tell you it was when you bought it?
uploading pics to photobucket...thats were the drain plug is...behind prop. one on the boat is forward of the prop on bottom of drive.....damn slow a*s comp
Might want to take a look at Service Bulletin 91-20
http://www.boatfix.com/merc/Bullet/91/91_20.pdf
Bravo gearhousings are not all the same
Good Luck Muc
what will happen if i put a new style bravo 1 lower in place of the older style? it seems that i have a oil line that runs through the gimble to the outdrive.
brian
