Trim gauge stuck
I have an '88 Four winns 215 Sundowner with 5.0L OMC Cobra sterndrive. The power trim works good but the gauge is stuck in the up position( has b een since I bought it).Any suggestions?
Re: Trim gauge stuck
Any suggestions?
Ayuh,.... Find the Sending Unit, it's probably the Problem...
I donno if replacements are available, or Not...
Maybe you can just clean up the wiring...
I just learned to live Without the gauge,... Now I use the "Seat of the Pants" gauge....
Lou C
Well you can't get an OE one anymore but Sierra makes one that is pretty much exactly the same...I got one off this site a few months back so try searching around for it....I find that these senders last at most 2 seasons in salt water....changing them is not fun either...the wiring goes through a nearly inaccessible place in the transom mount...
HT32BSX115
Howdy,
That sender is just a simple variable resistor with one end connected to ground and the "wiper" connected to the gage (or vise versa).
I was able to disassemble mine (back when I had a Kobra) and clean it out bit.
The other problem might be a shorted wire to the gage. remove the wire from the gage and see if it drops.
The gage will usually have 2 wires connected to it (excluding the light). 12v on one side and the sender wire on the other......the trim sender (variable resistor) completes the circuit to ground.
