Re: non-working gauges
I had a similar problem, on my cuddy with none of the gauges working, i used a multi meter to try and find the problem but it took me forever sticking my head under the dash, i ended up getting a 12V bulb and soldering a wire to the bottom and side contact of the bulb. As i was working with my head under the dash with not much light, i just connected the negative side to the common ground bar where all the black cables meet so i didnt need to hold it and started to touch all the red cables with the the other wire of my bulb so i could find where i had power quickly when the bulb lit up and give me some extra light to trace the wire.
Sometime technology dosen't win.
