lakeman1111
- Mar 8, 2010
- 9
Hello all-
I juist joined this forum yesterday! I am excited to learn a lot for all the experienced boaters out there. Here is my situation...
Lat summer i bought a 1994 Bayliner Capri 1800. It has a 120 Force outboard. I got a really good deal from a guy on craigslist. The body needed some TLC but the motor was strong. I did some basic cosmetic stuff to the hull with marinetex and gelcoat.
I dropped it in Lake Michigan last June and used it all summer. It worked great. However, there are some issues that need addressing....
I noticed some water in the bildge; and this wasnt from me getting in and out of the water. More like a gallon every hour. I believe its coming in through the engine mounts, guessing the seals are bad.
I also noticed a hummingbird device screwed in on the bottom of the transom. The screws were rusted...looks like some hack job done. Needless to say when i unscrewed it, water poured out. I stuck a screw driver all the way through! I propped the boat as close to perpendicular to the ground as possible....when it was all said and done, about 10 gallons of water came out! Where was all this water sitting? in any event , i plugged it and used it the rest of the summer.
My goal this spring is to redo the floor, possibly stringers, and i need to address the transom. There is no flexing of any kind but I dont like being on the big lake always worrying about a weak transom. any thoughts or ideas would be great appreciated. thanks much!
Lakeman
Lakeman
