mariner1900
- Dec 16, 2009
- 72
Hi all. I have a 74 model 140HP engine, serial # 3826715.
Have some noisy hydraulic lifters and rather than muck around stripping, cleaning and re-fitting then hoping they then work properly I am going to fit a new set. (yes tappets have been adjusted correctly but still noisy)
The original lifters appears to have been replaced by a new style lifter, P/N 72638. This hydraulic lifter appears also to be common on 4.3 V6 and 350 Chev engines fitted with hydraulic lifters. Please correct me if wrong.
As the lifters all appear to be common across the chev engines can I simply buy the lifters for a small block chev engine from my local auto parts dealer?
or is there a subtle difference in the mercruiser lifters?
