101mason101
Thread starter- Joined
- Mar 8, 2010
- 2
I just bought a 1994 bass boat and it has a 1998 blackmax 150 mercury on it. The boat was not well taken car of but the price was right.
The lower unit leaks oil from the lower drain screw plug, and the oil was white in color. I drained what was left and am not sure what oil to refill with or how much. The drain screw didn?t have a seal/gasket on it so I?m thinking that is why it was leaking.
Also it has some nicks in the leading edge of the aluminum casing in front of the screw and it looks like there is a small hole a couple inches up from the bottom, is that supposed to be there or is that a hole letting water into the gear oil?
thanks
thanks
