quick silver 3000 control box
the trim switch is not working on the control box and i cant seem to take it apart to figure out what is going on is there a trick to this or a sertin way to take apart thanks for any help at all:confused:
roscoe
Re: quick silver 3000 control box
yes, there is a trick.
roscoe
oh, you want to know the trick?
Push the neutral only button at the pivot point of the handle and push the throttle forward.
Remove the button, may have to pry the button out.
Remove the hex head bolt that is now exposed.
o.k i did as said and i do not see the hex head at all.the button came out easy and had a long plastic finger on the back of it.where is this screw at in there.please help
