nrf414
- Feb 16, 2008
- 573
Hey Everyone!
Today was a beautiful day in the Northeast with temperatures nearing 60 degrees. So, I decided to take the boat out of the heated garage and see if I could get it to start. It ran great last year and I have had the battery on a trickle charger for the last 2 weeks. So I hook up the water, hook up the battery and check my gauges. My Tach gauge went crazy when I first turned the key to the on position. It went backwards to -4500 RPM and the volt meter moved a hair but not showing any voltage. The battery showed 14V when measured. What would cause a tachometer to spike in reverse to the level it did? Is this the signs of a shorted tach or a bad ground along the way?
All accessories had barely enough power to operate: i.e. bilge blower ran at less than 1/2 the speed it normally does, lights were dim, radio worked, horn would not sound.
I spent some time taking voltage readings and going over the diagram in the manual and everything looked ok.
Engine is 1994 3.0 Mercruiser AlphaI GenII
Boat is 1994 Bayliner Capri 1952CN
