egclassic
- Dec 13, 2009
- 128
I have a 73' Merc 850. Took it out today for the first time since I bought this boat. The motor runs great and shifts good into forward. Reverse is where the problem begins, it just grinds when trying to shift into reverse.
In the driveway, on the muffs, it shifts flawlessly--forward to neutral then reverse. I replaced the water pump this winter and checked the prop rotation in each gear. In forward the prop will ratchet clockwise and not turn at all counter-clockwise, In Neutral prop will spin freely in both directions, and in reverse the prop will only turn a little in either direction. So I "feel" pretty confident that I got the lower unit back together properly.
Any ideas on what I'm missing here?
Thanks
Thanks
