I am not exactly a newbie to boating but am new to 24v systems. Long story short I just bought a boat that I know nothing about. Lowe 170W with a Johnson 50. It has 2 batteries(1 deep cycle and one marine starting) for the trolling motor and a marine starting battery for starting. The trolling batteries are wired what appears to be parallel at the posts but into what looks like a plug & receptacle setup just like at the front where the trolling motor plugs in. I am not sure what all is happening where this plug is wired in because I am reading 18v across either battery...which leads to my main question. What should the batteries read voltage wise? I had it in my head I would still only get 12v at the battery and that much higher would damage a normal 12v battery. I have no idea what the trolling motor is set up for. Its one of the Evinrude models and the bottom plate has been removed so there is no data whatsoever. I know it will only run if both batteries are connected so I assumed 24v. I am pretty sure the previous owner was even less knowledgeable as he had the cranking battery wired into this too when I got it. Apparently he was trying to charge all 3 off the 50s little charging system
