jasonachord
- Aug 27, 2009
- 37
I?m considering adding the SX series Smart Tabs this spring and getting rid of the Stingray III hydrofoil I added last year. The hydrofoil does help me plane easier with my underpowered 3.0 4 banger, but the boat leans to the left horribly with it on there. I?ve read that the Smart tabs will help with this problem and plane the boat off alot faster.
My question is with the way my transom is designed. I know with the SX series the actuator must be mounted on the same plane as the plate. Do you guys think the black line I placed on the picture of my transom would be to far inboard to mount the smart tabs? I?m also assuming the 60lb set would be best suited for my boat which is a 17?.
Thanks for any suggestions.
