Gluvit?
fishnducks
ok so i bought some to do the rivets on my aluminum. my question is, is it best to use it on the inside or outside?
thanks a bunch
tony
jspano
Re: Glovit?
Re: Glovit?
most use it inside below the deck (can be used outside)
uv rays hurt it
use the search option
gluvit
backlashed
Re: Gluvit?
How much did it actually take? I'm just about to that point, and have been trying to find some info on Gluvet. Do you do all of the rivets, and seams, or just the ones below the water line?
bananaboater
Ensign
Re: Gluvit?
Gluvit has a site with their instructions. I used bout 2/3 of the quart size for my 15 foot Jet. Went a bit above the water line in the bow area.
ezmobee
Re: Gluvit?
1 full qt. was JUST able to get my 18' completed.
Bob_VT
Re: Gluvit?
wear a mask
Any type of mask? Spiderman? Batman? :p I could not resist :D
When you do the gluvit I would not mix up much at a time....... at most I would mix 1/4 of the entire 2 lb can. It is really too good to have waste ;)
