Nandy
- Apr 10, 2004
- 2,145
The girlfriend bought this car a couple of weeks ago. The car has some details that need getting taken care of but the Hayes book I have is no help at all...
The oem radio volume knob does not work well (i replaced it tonight but it needs mention). You can turn the knob and the volume does change only if you turn it very slowly and sometimes it will actually go down when you are trying to get the volume up and viceversa. It really sounds as if the switch contact is not always been made. The LCD screen on top of the radio which is supposed to provide the display for the radio and a clock did not work at any time, even with the radio working. I guess since the radio has been removed I cant even get the clock on it to work?
The cigarette lighter nor the side mirrors controls work. Everything else seems to be in working order.
I went chasing fuses and the only fuse I could find were under the hood next to the battery. They were all in working order. I wonder if there is another fuse bay somewhere hidden that I was not able to see. I was wondering if there is a connection in common as these gadgets are all in close vicinity.
I know some of you do have access to better documentation and might be able to point me out in a better direction before I start taking everything apart. I rather have input from member that are familiar with this vehicle.
