Signal 20
- Dec 22, 2009
- 63
Ok I have been doing a lot of reading on here and there are just acouple things I just havent been able to figure out 100% yet and I am close to being able to make my complete order for my transom, stringers and deck restoration.
My first question is, please explain in short verious why I should use epoxy resin over polyester for my project or vise versa. Only thing I underdstand so far is epoxy is much more expensive than polyester. I also know that polyester requires wax as a finishing coat. Any other pros and cons???
Second question is I understand that I will need CSM for most of the job and I have read that most people alternate between CSM and Woven Roving with a final layer of CSM to make it smooth. Is that the right idea? So the order for the layup would be the following for the transom, stringers and deck...
bare wood saturated with resin.
then a layer of 2oz CSM.
layer of 18oz woven roving
then another layer of 2oz CSM
then your ready for gelcoat or paint?? is that sufficent
