FishHunter007
- Mar 2, 2010
- 39
Just thought I would post my project. Ill update as I go and see if there are any tips or ideas along the way. Thanks for any input.
We decided to go with normal 2x4's for the frame and then some pressure treated on any framing that is going to have constant contact with water. Every piece will get a fiberglass resin coating before the top goes on.
The middle bench is going to be a live well. Is it necessary to have a bilge pump for the live well or can it just be water with an aerator? Also, I have been trying to research to figure this out, but if you have a bilge pump to pump out the water of the live well, what do you use to fill it back up? for instance if you wanted to change the water while out on the boat.
I'll keep updating when more work is done.
