Re: "Chocolate milk" for lower gear oil in my 1985 merc 60hp
thats a helpful link... i'll give that a try... it wasn't taking on water until i put a new water pump in it... im gonna go through the pump again and make sure i didn't pinch a seal or something then run a pressure test... so besides the oil and vent screws (and a crack) it could only get there through under the water pump or the shaft seals right???
Not realy; beside the fill and vent screws (and a crack), there's 3 shaft coming out of an outboard lower unit: the drive shaft (the one that goes through the water pump) has two seals, the shift shaft one and the prop shaft two, plus the bearing carrier o'ring.
Click on Gear housing - Driveshaft and Gear housing - Prop shaft to look at the related diagrams:
http://www.ishopmarine.com/ishop/js...de=&pCode=&path=MM~&docId=276&docName=MERCURY | 1985 | 60 | 50/60 HP (3 CYLINDER) - 1060525&isForSupStore=true&cCatFilter=MM&eCatSupFldr=supplier-050-025-MM
Are you absolutely positive that this condition doesn't exist before your w/p change? BTW, most of the time people bought the complete costly w/p kit, including the baseplate and housing, when it's really not required...Next time, if there's no damage to the housing, order only the impeller, you'll pay like 15$ instead of 85$.
Did you happened to change the w/p baseplate? If so, there's 2 seals back to back under it for the driveshaft. Did you replace them?
