Re: Tips for prop selection with fishhawk 1750 and 90hp etec
Welcome,If you read the stickies at the top of the page and the helps at the prop store page you'll be able ask your question more clearly.You aren't likely to find someone with the same boat. If you can tell us your present prop size ,usually on the barrel or under the prop nut,your present rpm and speed we can get you started.
NADA says the 1750 is about 1600 lbs.Pretty beefy for a 90hp.You may be able to refine your setup to gain a little performance.Is the antiventplate(just above the prop) about even with the bottom of the boat.Most end up about an inch higher.
